mfry1379
I think deployment may be broken on my lansweeper server.
I haven't really used it for a while but I turned off a schedule back in February for a software deployment and now I am trying to create a new one. When I click deploy from the asset page, or when I try and deploy to a PC from the Package page nothing happens. There is no log entry created or anything. I have updated to the latest version and restarted the server, I have re-confirmed the scanning credentials as they had been changed and still no luck.
I am completely confused as this was pretty much working out of the box when it was first installed so I can't find any config that I may have 'broken'.
Any ideas?
mfry1379
I never quite closed this issue out. The issue was I had no threads allocated to deployment.
Just an FYI for everyone: deployments threads can be configured in the Lansweeper web console under Configuration\Server Options. These are set to 8 by default.
mfry1379
Daniel_B
Could you open the asset page of computers you would like to deploy on. Hit Rescan asset. Does it successfully rescan this computer?
Under Configuration\Your License, do you have a valid license applied for Lansweeper Professional or higher edition?
