dburson11
After updating to the current version 9.2.10.1, we can no longer go to a computers OU view and run deployments.
We can still deploy when on the specific single computer with no issues.
MarkPinn
I've updated to 9.4.0.8 which includes in its fixes:
Fixed: LAN-12575 Using the Deploy Package option in certain reports doesn’t result in deployments actually running
However it is still not deploying for me when using a dynamic list filtered on software installed, and then manually filtered on last successful scan.
Is it fixed for anyone?
I have a case logged with support but they just said it was a known problem and to check the release notes in a future version, but the "fix" is not working for me.
Mark.
WR_MEM
Any update on this LS support?
HStr
Same here.
Version 9.3.10.7
I think that no deployments on lists are working right now. I tried on a filtered software list - not working. Running on single assets work as expected.
Scheduled deployments on groups are still working though
MarkPinn
I'm also having the same issue after upgrading to v9.3.10.7. Single PC deployments work but those from asset groups do not. I've logged this with support.
Mark.
chogan201
I am seeing the same after updating to 9.2.10.1.
Trying to deploy to a filtered list of computers from the Windows Software page and the deployment does not start.
If I go to Deployment and specifically select those computers it works.
