computerdog
Hi Support
On the web console, there are two reports on the left hand menu,
Software overview
Computer Model overview
I would like to export the info on these pages but there aren't any export icons. Is it possible to export this info?
Many Thanks for your help
You will need to create a "normal" custom report for this which can be exported.
