Simon77
On the asset list, in a page for a windows there is a field for AD Location.
On the cloud version I need to filter by AD Location, then bulk update location and IP location to match the AD Location.
I can filter by IP Location or just location, I don’t seem to be able to filter by AD Location, is there a way to do this? Would help me out in a pinch that!
FrankSc
Hello Simon77,
Reading your description, I think setting up a custom view could help you here.
Additionally, you can create a custom report.
View software - Lansweeper Community
Thanks for the reply, I have tried to create a custom view but AD location is not an available field to search by. I have done a report which lists things, but then no way to bulk update after displaying the results.
