danielm
Due to having some machines with their win7 system restore forced off, i'd like to be able to now get them to update their policy and kick in a system restore point creation just once for good measure.
It seems, if you have it forced OFF via domain group policy, and the win7 pc crashes, it may on reboot try to restore and not being able to , find only the first(last) restore point and basically factory reset itself...
So far Im at
STEP 1
CMD = gpupdate.exe
[edit. removed /Force as I just read that can be BAD on large#s of computers]
Should I have any other actions? I'm running that as "system account" since I don't think i need any special other access.
i'm not sure for the success codes, but it seems to work as is.
Now I just wonder how we can get restore point to start.
Any ideas?
Moved this to the main forum as this is not really a report question. We can't provide assistance for creating specific deployment packages, but a quick Google search did return this article on creating system restore points.
