LifeInIT
I have an OU in Active Directory of all Disabled Users.  However we need to do some basic house keeping by deleting these profiles off of computers that are still being used by other users.  How can I create a report that gives me either ALL of the profiles on a PC by name, or matches the profiles on a PC by those in the Disabled Users OU?
DavidPK
We've created a sample report. Instructions for adding this report to your Lansweeper installation can be found here: https://www.lansweeper.com/knowledgebase/how-to-add-a-report-to-your-lansweeper-installation/
If you are interested in building or modifying reports, we do recommend:
• Reviewing some SQL tutorials, as the Lansweeper report builder is a standard SQL editor. If you know SQL, you know how to build Lansweeper reports as well. This seems like a good tutorial: https://www.w3schools.com/sql/
• Making use of our database dictionary, which explains in great detail what each database table and field stores. More information on the dictionary can be found here: https://www.lansweeper.com/knowledgebase/accessing-the-lansweeper-database-documentation/
Checking out our report library: https://www.lansweeper.com/report/
Select Top 1000000 tblAssets.AssetUnique,
  tblUsersInGroup.AssetID,
  tblAssets.Domain,
  tblAssets.Description,
  tblUsersInGroup.Domainname,
  tblUsersInGroup.Username,
  tblUsersInGroup.Lastchanged,
  tsysOS.Image As icon,
  tblUsers.Disabled
From tblUsersInGroup
  Inner Join tblAssets On tblUsersInGroup.AssetID = tblAssets.AssetID
  Left Join tblUsers On tblUsers.AssetID = tblUsersInGroup.AssetID And
    tblUsers.Name = tblUsersInGroup.Username
Where Not Exists(Select Distinct * From (Select tblAssets.AssetName As Domain,
      tblUsers.Name As Username
    From tblAssets
      Inner Join tblUsers On tblAssets.AssetID = tblUsers.AssetID
    Where tblUsers.BuildInAdmin = 1 And tblUsersInGroup.Domainname Like
      tblAssets.AssetName And tblUsersInGroup.Username Like tblUsers.Name
    Union
    Select tsysadmins.Domain,
      tsysadmins.AdminName As username
    From tsysadmins
    Where tblUsersInGroup.Domainname Like tsysadmins.Domain And
      tblUsersInGroup.Username Like tsysadmins.AdminName) DERIVEDTBL) And
  tblUsersInGroup.Admingroup = 1 And tblAssetCustom.State = 1
Order By tblAssets.AssetName
