The platform-first version of Lansweeper is a completely new way of using and setting up Lansweeper in your organization. The platform first version has no local web console, instead, it uses the cloud platform site as the only way to configure and control Lansweeper.
This means that all the parts that are greyed out in hybrid sites, are fully accessible down to full control over your scanning server options.
Since it is a completely different setup, this isn’t available as an option for your production environment just yet. However, with the use of a VM you can try it out to see the UX and UI improvements we’ve made.
You can find all the instructions to get started in Knowledge Base Knowledge Base - Lansweeper Community
0 REPLIES 0
