swsswr
we use some HP servers. iLos are discovered as ssh devices with their corresponding IP. I habe enabled snmpv3 on iLo and added those credentials in lansweeper, as well as mapped the credential to the correct IP Range. How do I mak esure snmp is used to scan that iLo?
cheers, swsswr
swsswr
Ok, just hit the rescan button and newly created snmpv3 credentials where used. Also the access typ switched from ssh to snmp
