11-21-2019 11:12 AM
Looks like scanning HP warranty on some devices is broken when we're scanning against the HPE database.
See this:
Parsing error: Cannot parse 'https://support.hpe.com/hpsc/wc/public/find?lang=us&rows%5B0%5D.item.countryCode=US&rows%5B0%5D.item.serialNumber=CNB7G7W36J'
If I manually copy the URL above and end up at the HPE site it states that:
"The information you provided does not match our records. Please review your entry again and make any necessary edits or contact HPE for more assistance."
If one uses the HP warranty check site (not HPE):
https://support.hp.com/us-en/checkwarranty
Its happy and doesn't produce any error, just provides the correct warranty details.
Is there a way to add an alternative warranty check URL to lansweeper?
Solved! Go to Solution.
General Discussion
02-21-2020 01:52 PM
i wrote for myself Powershell script to get all HP computers/laptop assets from DB, use Powershell module to get warranty info thru SOAP API and update asset in DB.
You will need these PS1 modules:
https://github.com/dotps1/HPWarranty
https://docs.microsoft.com/en-us/sql/powershell/download-sql-server-ps-module?view=sql-server-ver15
$assets = Invoke-Sqlcmd -ServerInstance servername -Database lansweeperdb -Username lansweeperuser -Password 'password' -Query @"
SELECT a.AssetID, a.AssetName, b.Serialnumber, b.SystemSKU
FROM lansweeperdb.dbo.tblAssets a, lansweeperdb.dbo.tblAssetCustom b
WHERE a.AssetID = b.AssetID AND
a.Assettype = -1 AND
b.Warrantydate is NULL AND
b.Manufacturer in ('HP','Hewlett-Packard');
foreach ($asset in $assets) {
$assetId = $asset.AssetID
$assetName = $asset.AssetName
$warranty = ((Get-HPIncWarrantyEntitlement -SerialNumber $asset.SerialNumber -ProductNumber $asset.SystemSKU).OverallEntitlementEndDate | Measure-Object -Maximum).Maximum
Write-Output "$assetID $assetName $warranty"
UPDATE dbo.tblAssetCustom
SET Warrantydate = '$warranty'
WHERE assetID = $assetId
06-25-2020 08:14 PM
06-25-2020 07:57 PM
https://www.lansweeper.com/knowledgebase/adding-manufacturer-support-links/
06-25-2020 08:10 PM
Richie_Rich wrote:
The following KB shows how to edit the Asset warranty URL FYI
This URL is not used to scan the warranty on the computer. Granted you can go to the asset and click on the serial number to get the warranty info, but this will not help with things like the warranty report.
06-19-2020 05:01 PM
03-25-2020 12:10 PM
Warranty lookup was been the specific reason, that we have bought this product.
Lansweeper connects to the HP Enterprise server, when looking up clients.
Look at https://github.com/dotps1/HPWarranty/tree/master/HPWarranty/Public
You will see that there at two different scripts.
I believe an attribute like chassis type, can be used to determine which server to contact.
Honestly.
This has been a problem for something like 6 months…
I have sent you at least two mails explaining that LS looks up warranty on the wrong server/Company
As I have explained in my email, HP and HPE have split into two different companies - and have different warranty databases. It may well be that the HP API does not work, but fix the f... pointers first.
I am so disappointed that you haven't fixed this.
My colleagues are loosing confidence in the product.
Lars Kruse
€ 24.000 p.a. customer.
03-25-2020 09:55 AM
LanSweeper asks "https://support.hpe.com..." for Notebooks and Computers. Shouldn't this be hp.com? If i do the Check manually, i go to "https://support.hp.com/".
It's a real pain at the moment, customers rely on this information.
Thanks for fast patching.
greets
martin
05-27-2020 03:34 PM
Martin Wildi wrote:
I do have the same Problem 😞
greets
martin
I totaly agree with this, it's not the right url used to check the Wks warranty.
I cannot remember where, but at a time, you were able to put a list of url for the warranty check in lansweeper.
Anyone have news about this issue ?
Does anyone have news about this
02-21-2020 01:52 PM
01-13-2021 07:28 PM
This saved me so much time. I can't thank you enough.
I altered your script slightly to pull the purchase date as well. Uploaded 1600 devices with missing information within a few hours. Would have taken me forever, now I have reliable data for planning.
Thanks again.
$assets = Invoke-Sqlcmd -ServerInstance server -Database lansweeperdb -Username lansweeperuser -Password 'password' -Query @"
$StartDate = ((Get-HPIncWarrantyEntitlement -SerialNumber $asset.SerialNumber -ProductNumber $asset.SystemSKU).OverallEntitlementStartDate | Measure-Object -Minimum).Minimum
Write-Output "$assetID $assetName $warranty $StartDate"
SET Warrantydate = '$warranty',PurchaseDate = '$StartDate'
08-25-2020 06:09 PM
This worked great, thanks for the info. Even used to to update the purchase date.
