Moopere
Hello Folks,
Looks like scanning HP warranty on some devices is broken when we're scanning against the HPE database.
See this:
Parsing error: Cannot parse 'https://support.hpe.com/hpsc/wc/public/find?lang=us&rows%5B0%5D.item.countryCode=US&rows%5B0%5D.item.serialNumber=CNB7G7W36J'
If I manually copy the URL above and end up at the HPE site it states that:
"The information you provided does not match our records. Please review your entry again and make any necessary edits or contact HPE for more assistance."
If one uses the HP warranty check site (not HPE):
https://support.hp.com/us-en/checkwarranty
Its happy and doesn't produce any error, just provides the correct warranty details.
Is there a way to add an alternative warranty check URL to lansweeper?
zaty
i wrote for myself Powershell script to get all HP computers/laptop assets from DB, use Powershell module to get warranty info thru SOAP API and update asset in DB.
You will need these PS1 modules:
https://github.com/dotps1/HPWarranty
https://docs.microsoft.com/en-us/sql/powershell/download-sql-server-ps-module?view=sql-server-ver15
$assets = Invoke-Sqlcmd -ServerInstance servername -Database lansweeperdb -Username lansweeperuser -Password 'password' -Query @"
SELECT a.AssetID, a.AssetName, b.Serialnumber, b.SystemSKU
FROM lansweeperdb.dbo.tblAssets a, lansweeperdb.dbo.tblAssetCustom b
WHERE a.AssetID = b.AssetID AND
a.Assettype = -1 AND
b.Warrantydate is NULL AND
b.Manufacturer in ('HP','Hewlett-Packard');
foreach ($asset in $assets) {
$assetId = $asset.AssetID
$assetName = $asset.AssetName
$warranty = ((Get-HPIncWarrantyEntitlement -SerialNumber $asset.SerialNumber -ProductNumber $asset.SystemSKU).OverallEntitlementEndDate | Measure-Object -Maximum).Maximum
Write-Output "$assetID $assetName $warranty"
UPDATE dbo.tblAssetCustom
SET Warrantydate = '$warranty'
WHERE assetID = $assetId
31 REPLIES 31
TBMPS
I am not looking at my servers. I am looking at my desktops and laptops.
TBMPS
Trying out the script in #12. However it is only putting the date "1900-01-01" in the warranty. When I run the script, there is no error. Is there something that might need to be done to get this to work correctly, or has this script been shutdown too?
Thanks.
zaty
Thanks.
unfortunately, it works only for HP assets (desktops, laptops) but not for HPE assets (servers, switches etc) 😞
filip_heens
So strange that reply #12 from zaty works perfectly (in my environment) but that Lansweeper can't seem to get it working.
Well thanks zaty as I can use your work around for the time being 😉
Bruce_B
No news to share as of this moment unfortunately.
filip_heens
Are there any updates on this.
I know that Lansweeper was working on this, but I can't find any updates...
mwrobo09
This should be made a high priority. This has not been working for some time, and I am trying to do planning for next year and many of my devices have not been pulled in a long while. I am manually going through 1000 devices trying to enter the information.
Please fix ASAP.
FrankSc
We are indeed looking into this. We realize that warranty scanning is a valuable feature.
As this issue was initiated by changes made to the HP Warranty API, we are currently in communication with HP to find a solution to get this working again.
jan_prins
DearSupport
Are you currently investigating thsi issues? I have also submitted a ticket for this but no respnse.
I think 6 months of waiting is not good enough.
