MWLInfraTeam
Has anyone integrated CrowdStrike with Lansweeper.  I was hoping to use CrowdStrike sensor data to pull asset information into Lansweeper.  Could not really find any quick guides for guidance on how to do this and was hoping for some pointers or directions on where to start looking.  I assume this should be possible with a little bit of work but not something that seems so out there.
Jacob_H
Hey MWL - this is a perfect thing to use Flow Builder for - a low-code/no-code integration/workflow platform - you can sign up here:  https://www.lansweeper.com/product/beta/
Once you have access, you can follow this Pro-Tip to get you going (try the walkthrough vs import - but if you do the import, you might have to delete the connections and re-add them) - https://www.lansweeper.com/blog/pro-tips/intune-automations/
Watch the video as you can see me bumble through using flow builder to give you an idea of how it works in general -  then, swap out the intune connector with a custom HTTP connector, set up CS for access, put the secret/etc in the connector, and change the asset match code block to match on whatever you have to match with, which looks like (according to looking with GPT)  hostname, os_version, serial_number mac_address, ip, manufacturer, and model
The Pro-Tip asset match code block matches on serial number, and if no match, hostname, but you can add to that if you wish to ensure a good match.
Then, use your imagination on useful things to pull from Crowdstrike -  device_id (obviously grab that key! great for passing along to ITSM/etc) health status, containment status, last logged in user, public IP address....
then - report on it, dashboard it, or pass it on to other systems -  couple this with properly classifying assets (https://www.lansweeper.com/blog/pro-tips/the-importance-of-asset-classification/) and you can have some really good reports for compliance.   Then, take that flow you made, copy it, and go crazy grabbing data from your other systems and make Lansweeper a single-pane-of-glass to see everything!
