dsnider
We are delving into CIS 2 which deals with Software inventory.  We are looking to add a couple of custom fields to each software as we are determining if a software is authorized (I know the authorization function is limited to On-prem - we have cloud and on prem).
We are looking to add a yes/ no, boolean type of field - (Is this software supported?) and a free form text field to add notes explaining the reason for its use.
I have not found a way to even edit a software entry.  Does anyone know how or if this can be accomplished?
Thanks in advance - Dena
FDUB
+1 for this
Obi_1_Cinobi
Hello there!
Unfortunately, such a feature is not available currently. If you would like to log a feature request for this, please raise a support case: https://www.lansweeper.com/contact/contact-support/
If you have issues with accessing the Support Portal, please use this URL instead: https://www.lansweeper.com/contact/contact-support-case/
