Bucklebery
I just installed on SBS 2003 Premium - including ISA 2004. Can see clients but each client has The RPC server is unavailable 0x800706BA. So I checked ISA and the following sometime it lets lansweeper through and other times it doesnt. Any ideas what I should do? Many thanks
This entry seems to pass through my credential but the next one doesnt.
Allowed Connection DUNAMIS 31/10/2009 10:16:33 p.m.
Log type: Web Proxy (Forward)
Status: 0 The operation completed successfully.
Rule: SBS Internet Access Rule
Source: Internal ( 192.168.0.11:0)
Destination: External ( 192.168.0.1:80)
Request: GET http://www.lansweeper.com/forum/themes/Lansweeper/topic_sticky.png
Filter information: Req ID: 0f6e3d91
Protocol: http
User: NEWHOPE\Ian
Additional information
Client agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1) ; .NET CLR 1.1.4322; .NET CLR 2.0.50727; MS-RTC EA 2; InfoPath.2; OfficeLiveConnector.1.3; OfficeLivePatch.0.0; .NET CLR 3.0.4506.2152;
Object source: Not Modified Processing time: 1
Cache info: 0x1002 MIME type:
Denied Connection DUNAMIS 31/10/2009 10:16:33 p.m.
Status: 12209 The ISA Server requires authorization to fulfill the request. Access to the Web Proxy service is denied.
Destination: External ( 192.168.0.1:8080)
Request: GET http://www.lansweeper.com/forum/themes/Lansweeper/topic.png
Filter information: Req ID: 0f6e3d94
Protocol: http
User: anonymous
Object source: Processing time: 1
Many tshnks
Bucklebery
Update: I have
1. removed lansweeper from my SBS Premium with ISA.
2. Restored my sharpoint site
3. Enabled remoted admin on clients - see previous post
4. confirmed no 3rd party firewall interfereing
5. Checked I canping computername, and ip
Now waiting to hear if it is ok to install LS on XP pro cleinet with local database and best praftice to do so. Many thanks - Ian
19 REPLIES 19
Bucklebery
Just for grins - I rebooted the xp clinet - and it looks like we are now having some success! I will confirm tomorrow!
Bucklebery
C:\Documents and Settings\Ian>netsh firewall show state
Firewall status:
Profile = Domain
Operational mode = Enable
Exception mode = Enable
Multicast/broadcast response mode = Enable
Notification mode = Enable
Group policy version = Windows Firewall
Remote admin mode = Enable
Ports currently open on all network interfaces:
Port Protocol Version Program
1038 UDP IPv4 C:\Program Files\Bonjour\mDNSResponder.exe
26675 TCP IPv4 (null)
135 TCP IPv4 C:\WINDOWS\system32\inetsrv\inetinfo.exe
137 UDP IPv4 (null)
139 TCP IPv4 (null)
138 UDP IPv4 (null)
1184 UDP IPv4 C:\Program Files\Microsoft Office\Office12\GROOVE.EXE
1185 UDP IPv4 C:\Program Files\Microsoft Office\Office12\GROOVE.EXE
1211 UDP IPv4 C:\Program Files\Microsoft Office\Office12\GROOVE.EXE
5353 UDP IPv4 C:\Program Files\Bonjour\mDNSResponder.exe
4347 TCP IPv4 (null)
4347 UDP IPv4 (null)
9524 UDP IPv4 (null)
9524 TCP IPv4 (null)
3389 TCP IPv4 (null)
3408 TCP IPv4 C:\WINDOWS\system32\svchost.exe
63830 UDP IPv4 C:\Program Files\Bonjour\mDNSResponder.exe
445 TCP IPv4 (null)
2492 TCP IPv4 C:\Program Files\Microsoft Office\Office12\GROOVE.EXE
3703 TCP IPv4 (null)
3704 TCP IPv4 (null)
50901 TCP IPv4 (null)
50900 TCP IPv4 (null)
2869 TCP IPv4 (null)
1900 UDP IPv4 C:\WINDOWS\system32\svchost.exe
6004 UDP IPv4 C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE
2967 TCP IPv4 (null)
990 TCP IPv4 C:\Program Files\Microsoft ActiveSync\rapimgr.exe
33761 TCP IPv4 C:\Program Files\Skype\Phone\Skype.exe
33761 UDP IPv4 C:\Program Files\Skype\Phone\Skype.exe
____________________________________________________________
When I do a telnet HP26293279738 135 it comes back with a black screen but the cmd box shows in the blue banner at the top the words Telnet HP26293279738 -
1) a "telnet remotemachine 135"
2) "netsh firewall show state" on the remote machines.
Bucklebery
Now installed on XP pro sp3. Connection tester still can't get thur to other machines. What screen shot do you need to see?
Bucklebery
Update: I have
Yes, that shouldn't be a problem.
On your XP client it's best to turn your firewall off for performance.
Bucklebery
Have now enfored the policy
Firewall status:
Profile = Domain
137 UDP IPv4 (null)
139 TCP IPv4 (null)
138 UDP IPv4 (null)
445 TCP IPv4 (null)
Can ping a client
Microsoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
C:\Documents and Settings\Administrator>ping HP26293279738.newhope.local
Pinging HP26293279738.newhope.local [192.168.0.11] with 32 bytes of data:
Reply from 192.168.0.11: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.0.11:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Now what?
Bucklebery
While I am trying to find out how to apply this policy properly - still hasn't deployed Can I ask a point of Point of Clarification on best practice?
Is it better to have lansweeper installed on the SBS 2004 Premium box - with ISA or better to have it in an xp client that is on all the time? Reason I ask is my Sharepint site seems to have died when I installed Lansweeeper on the SBS box - where sharepoint is installed? Many thanks for you help
on the xp client you can test with "gpresult" this show all applied policies.
You can also force a policy refresh on the client with "gpupdate /force"
