serge_pirotte
Dear,
How can I make a printout from an article into the knowledgebase ?
Not possible yet ?
Thank you.
Karel_DS
There is indeed currently no button for a print preview of an article. This will be added in version 6.1, but this is still a long way off. However for an easy workaround you can select the text of the article and then when going to print choose selection as your print range.
