‎06-12-2015 08:31 PM
Solved! Go to Solution.
‎06-30-2015 08:16 AM
‎04-14-2016 01:24 AM
‎08-19-2020 12:03 AM
Karel DS wrote:
Just some info.
The way a CSV file is formatted can be changed to other characters under Control Panel -> Region and Language -> Additional Settings... -> List separator. The separator cannot be a comma if for instance the decimal symbol is already a comma. However this doesn't always immediately seem to work.
As a workaround you could save a file in Excel format, open it in Microsoft Excel (or Open Office), then save it as a CSV file.
‎06-29-2015 11:55 AM
‎06-17-2015 08:43 PM
‎06-15-2015 02:31 PM
