SEC_ALERTS
Hi Team,
LanSweeper does not capturing Serial No of the some machines.
What need to do here?
Your help would be really appreciated.
Regards,
SEC_ALERTS
Lansweeper relies on WMI to get this information.
You can try a bios update and checking if the serial number is set correctly in the bios.
SEC_ALERTS
Thanks for your reply.
I Will verify it and update you.
SEC_ALERTS
Hi Team,
If possible, please provide guideline steps.
Regards,
SEC_ALERTS
SEC_ALERTS
Hi Team,
Thanks for your information.
I have tried this command manually and get no result.
What steps I need to perform such machines.
Your help would really appreciate.
Regards,
SEC_ALERTS
This value is scanned from WMI class win32_computersystemproduct.
The class gets this information from the Bios.
You can run this command manually on the remote computer to check the output:
wmic path win32_computersystemproduct get IdentifyingNumber
