sullivane
We, like many places, have different IP addresses for different buildings.
It would be awesome to set it up so that you can enter a range to associate a location.
Example:
10.0.1.0 - 10.0.1.255 - Building1
10.0.2.0 - 10.0.2.255 - Building2
Then LS could put enter into a field (either location or building...maybe user can select?) Building1 when the IP is seen in that range?
You can already set this up with IP locations, under Configuration\Asset Groups. Assign names to your IP ranges and Lansweeper will list the IP location on the asset's Lansweeper webpage. When hovering over the Assets menu, you'll also be able to click on an IP location to see the assets contained within.
sullivane
I will try that out, thanks!!
