manelnas
Hello Team,
Is there a way to automate the Asset Location according to the IP Location?
Regards
Putting assets on a location map has to be done manually. You can add multiple asset at the same time, but even if you were able to set a specific IP location to a specific location map, Lansweeper still would not know where to put the assets on the map.
