dusan
Hello
After deleting a computer, its name still appears in the LSAgent menu. Wouldn't it be correct to automatically delete it after deleting the computer here as well.
Regards
Dušan
6 REPLIES 6
dusan
Yes, it is disabled. But I wish to be deleted from "LsAgent Groups Configuration"
dusan
In the picture you can see that there is no date in the "Last LsAgentScan" column. There are computers here that have been inactive for years, so I don't think they will be automatically deleted. Must I manualy delete removed computer from that list?
David_GF
We recommend opening a case with our Support team, as troubleshooting this issue requires logs that should not be shared in the forum
How to contact support?
Using the GatherLogs tool.
Sweep that LAN, sweep it!
dusan
Assets were deleted from lasnweeper on premise via Edit asset and then Delete asset. Asset is no longer on network.
David_GF
The asset should appear as disabled in the LsAgent asset group and dissapear from there after the next scheduled scan time. If removed from that section, it is deleted from the asset groups.
David_GF
Where was the asset deleted from? Is LsAgent still installed and running in the asset?
