malvivent7
Hi, i have upgraded my lansweeper installation 6 to the last v7; all good but suddenly my lspush v 6.0.100.32 cannot comunicate with central server and this is the message that i receive if i start the lspush program with the /showresult param:
6.0.100.32 http://192.168.xxx.xxx:9524 EZDecompressionError: Data error.
What's wrong??
Thanks in advance on helping me
The following error was found in the errorlog: INFO Cannot configure SSL port: 9524. Lansweeper does not support SSL on Vista / Server 2008
As SSL is currently not available on the scanning service (installed on Vista or Server 2008), the (fallback) http protocol will be used to send/receive the information. There is currently an issue with packaging the LsPush scanning result for this protocol. As such, it has been passed on to our development team so they can create a fix for this issue. Unfortunately, I cannot provide an estimated release date for the Lansweeper version that will include this fix.
To resolve the issue at this point, it's suggested (if possible of course) to migrate the scanning service to another server with a more recent OS that allows this SSL connection.
Migrating to 2008R2 should be sufficient. The steps to migrate your installation can be found here: https://www.lansweeper.com/knowledgebase/move-lansweeper-to-different-server/
cpb
It has been over 3 months--has there been any movement on the development team providing a fix for this issue?
And do you seriously consider "Move Lansweeper to a different server" to be a solution?
honzaj
Hello team,
I have exactly the same problem with lspush usage on my server after upgrading to version 7.
Thanks for the solution in advance
I see you contacted our support team. They will take a look at it. Once it's been resolved I'll try to follow up.
