Grigori
Hi all,
We have sensors in different IP networks which appear as webserver (only IP pingable).
To easier spot them, I added a static group with their fixed IP address.
I would like now to mass edit those assets, to change the type from Webserver to Sensor, but there is no mass edit button if I click on the specific asset group.
Is there any way to do it?
Best way to do it is the following:
Go to the assets page.
Use the filters at the top to only select the assets you want to change.
Select the assets with the checkboxes on the left-hand side.
Use the "Edit Fields" button on the left and and can change all the assets type in bulk.
I tried, but unfortunately there is no filter for static groups, and because not all Webserver are Sensors, I can’t see in the overview, which one is a Sensor (has a group tag).
