Noobie
Hi, i want to know if the advanced filter view in cloud with the option of Asset Groups works with groups create in on-prem infra. I can´t get to work this filter, if any could help with be great.
DavidPK
Hi Noobie,
You are able to manage all groups created in on-prem in sites. You first must enable the feature. This should allow you to use the advance.
In our internal testing it works with the advance filtering. We are able to see the group that was create in on-prem when filtering on that specific group.
