12-07-2018 07:41 PM
12-27-2022 04:49 PM
We currently have the Lansweeper DB on an Azure SQL managed instance, but we can't use the cloud feature of Lansweeper because it's still not supported. Disappointing that this is still holding us up from using the full potential of Lansweeper
12-11-2018 01:20 PM
03-11-2022 07:16 PM
Esben.D wrote:
Unfortunately it won't currently be possible to install a Lansweeper database on Azure SQL Server. The installer specifically checks for the sysadmin user role, and as this doesn't exist in Azure SQL Server, the installation will always fail at this point.
Installing the Lansweeper DB on a Windows server running in Azure that has a SQL Server instance installed on it is possible.
10-14-2022 03:59 PM
Hello there!
Unfortunately, Lansweeper cannot be used on SQL as a Service yet. Currently, you can only set up a Windows machine in Azure and install a SQL Server instance on that machine. This feature is still on our customer wish list, but we aren't able to guarantee that this feature will be implemented or provide you with an estimated release date at this time.
08-22-2023 02:37 PM
This would be an interesting & much-appreciated option to as there seem no plans to bring the helpdesk component of Lansweeper to the Cloud version (that's blocking us from going fully cloud in this) and the azureSQL route looks about 3x less expensive than a Windows VM+ SQL server..?
10-14-2022 04:08 AM
I am also keen to know if there is any progress on this or not.
