ddarlage
We are needing to modify the IT Owner:, Bus Owner, and Support Owner per IP range.
Is something like this possible?
I assume those fields are created using custom fields then?
It's important to know whether the fields you are mentioning are made using custom fields or by using relations. The database tables where the information is stored depends on it. Either way, the easiest way of doing it would be to run a database script since there is no way to change it in bulk in the web console.
You can find more information about the asset custom fields and the database tables here: https://www.lansweeper.com/knowledgebase/configuring-and-adding-data-to-asset-custom-fields/
ddarlage
When you edit an asset you can to the fields below.
Server Name: Bob the Builder
IT Owner: DEV-OPS
Bus Owner: Ron Pits
Support Owner: Todd Smith
So I would like to be able to bulk add, lets say Todd Smith to Support, Ron Pits to Bus Owner, and IT Owner Dev-OPS to any Asset within the 192.168.1.0/24 network.
How are these owners currently linked to the assets? Are you using relations? If you can give me an example I can see if I can get you a more concrete answer.
