RemiB
Hello team,
I look for a solution, i have a couple of NVR on my network and i can't see it.
My goal is to put every camera on my inventery.
I scan the right Vlan and i have the right credentials.
have a great day!
Hendrik_VE
Without SNMP it will be hard to discover the device correctly. If you have a scanserver in the same vlan, then the CDR feature should recognize it as a video device (see https://community.lansweeper.com/t5/scanning-your-network/credential-free-device-recognition-cdr/ta-...). But like I said, this only works when your scanserver is in the same broadcast domain as the device, because it needs at least a MAC address to create a fingerprint of your device.
RemiB
I still not seeing my Camera when i scanning my NVR can someone help me pls
RemiB
Do we have a alternatif if i don't have snmp on my nvr
Hendrik_VE
Hendrik_VE
Hi Remi,
Most NVR's and other camera equipment support SNMP. Make sure you've set up SNMP correctly on your camera device and configure the corresponding SNMP community under Scanning>Scanning Credentials (don't forget to map the scanning credentials to the scanning target!).
If it doesn't work, try troobleshooting with the devicetester tool (see https://community.lansweeper.com/t5/troubleshooting-scanning-issues/troubleshooting-snmp-scanning-is...)
RemiB
We have Lorex NR932X i dont see enything about SNMP on it
