Options
‎04-27-2015 03:20 PM
So far this effects Polycom VSX 7000 and HDX 7000 HD cameras. I have not fully tested every model so there could be others. Some such as the QDX 6000 are scanned and recorded in lansweeper perfectly.
I've found that I can scan them with the devicetester without any problems. But the automated IP range scanning never catches them. I then manually added one asset, but after its added if I rescan the asset, it is deleted almost instantly. So devicetester can scan it, but lansweeper refuses to store and info on it.
Any ideas?
Any ideas?
Solved! Go to Solution.
Labels:
General Discussion
Options
‎04-28-2015 10:47 AM
Have a look at this forum topic. I would recommend sending the information requested in that topic to support@lansweeper.com. (Jdteichmer's problem devices were switches, but the debugger should work for any devices scanned through SNMP.)
Options
‎04-30-2015 03:16 PM
Thanks! Thats what I figured.
Lansweeper support is great!!
Options
‎04-30-2015 08:29 AM
In order to remove a certain MAC address, run a script like
or
under Configuration\Database scripts, section Database scripts.
DELETE FROM tsysMacBlacklist WHERE Mac LIKE '01:12:23:34:45:56'
GO
or
DELETE FROM tsysMacBlacklist WHERE Comment LIKE 'YourComment%'
GO
Options
‎04-29-2015 12:00 AM
Can you confirm what the SQL script would be to UN-blacklist a MAC? I may have gone a tad to far and blacklisted to many MACs.
Thanks,
Just so everyone knows.
The loopback (pseudo ethernet) MAC for the Polycom VSX 7000 cameras is 4C:50:42:41:43:4B
The loopback (pseudo ethernet) MAC for the Polycom HDX 7000 cameras is 9A:64:2F:98:DD:38
Those are the only two I needed to blacklist.
Thanks,
Options
‎04-28-2015 10:13 PM
That was it!! Thank you! I doubt I would have caught that.
I found that these Polycom cameras have 2 MAC's when scanned with the Devicetester. And one of those MACs is duplicated. Probably the onboard network port for attaching a PC.
I plugged this MAC into the SQL script from that post and it cleared up the problem!!
Thanks again!!
Thanks again!!
Options
