MrVal
So far this effects Polycom VSX 7000 and HDX 7000 HD cameras. I have not fully tested every model so there could be others. Some such as the QDX 6000 are scanned and recorded in lansweeper perfectly.
I've found that I can scan them with the devicetester without any problems. But the automated IP range scanning never catches them. I then manually added one asset, but after its added if I rescan the asset, it is deleted almost instantly. So devicetester can scan it, but lansweeper refuses to store and info on it.
Any ideas?
Have a look at this forum topic. I would recommend sending the information requested in that topic to support@lansweeper.com. (Jdteichmer's problem devices were switches, but the debugger should work for any devices scanned through SNMP.)
MrVal
Thanks! Thats what I figured.
Lansweeper support is great!!
Daniel_B
In order to remove a certain MAC address, run a script like
DELETE FROM tsysMacBlacklist WHERE Mac LIKE '01:12:23:34:45:56'
GO
or
DELETE FROM tsysMacBlacklist WHERE Comment LIKE 'YourComment%'
GO
under Configuration\Database scripts, section Database scripts.
MrVal
Can you confirm what the SQL script would be to UN-blacklist a MAC? I may have gone a tad to far and blacklisted to many MACs.
Thanks,
Just so everyone knows.
The loopback (pseudo ethernet) MAC for the Polycom VSX 7000 cameras is 4C:50:42:41:43:4B
The loopback (pseudo ethernet) MAC for the Polycom HDX 7000 cameras is 9A:64:2F:98:DD:38
Those are the only two I needed to blacklist.
MrVal
That was it!! Thank you! I doubt I would have caught that.
I found that these Polycom cameras have 2 MAC's when scanned with the Devicetester. And one of those MACs is duplicated. Probably the onboard network port for attaching a PC.
I plugged this MAC into the SQL script from that post and it cleared up the problem!!
Thanks again!!
