pryan67
Ever since upgrading our LS to the latest version, printers (which we exclude from scanning) are being seen as switches rather than printers.
They are being scanned via SNMP, and have OIDs but they're being seen as switches, even though they correctly identify the page counts as well as model numbers.
Any suggestions?
Obi_1_Cinobi
Hello there!
If you're using SNMP, you can use the OID to map it as a printer. Mapping instructions can be found here:
pryan67
Thank you, I tried that, but it's not working, it still sees it as a switch.   Perhaps I'm incorrect in saying they have OIDs.  In the "summary" page it shows an OID, but nothing under "scanned OIDs"...
Obi_1_Cinobi
Hello there!
Would you mind sending an email to support@lansweeper.com so that we can take a more detailed look into this issue?
