‎07-08-2009 07:01 PM
Then I've reinstalled lansweeperservice on a server and web site on another server (I've tryed both 3.5.1 and 3.5.2 beta versions).
Now situation is:
- db seems to run correctly;
- lsmanage.exe run correctly (I can see the db);
- lansweeperservice.exe can't start due to login error (Cannot connect to database, check your config file, service will be stopped Cannot open database "lansweeperdb" requested by the login. The login failed.
Login failed for user 'lansweeperuser'.)
- web site doesn't work due to login problem too as follow:
System.Data.SqlClient.SqlException: Cannot open database "lansweeperdb" requested by the login. The login failed.
What's the problem?
In attach web.config and Lansweeperservice.exe.config
Solved! Go to Solution.
General Discussion
‎07-13-2009 11:23 AM
- delete lansweeper schema (databases\lansweeperdb\security\schemas)
- delete lansweeperuser (databases\lansweeperdb\security\users)
- delete lansweeperuser (security\logins)
- create lansweeperuser (security\logins)
- create lansweeperuser (databases\lansweeperdb\security\users)
- create lansweeper schema (databases\lansweeperdb\security\schemas)
Now it seems to go properly but I'm not sure to see any improvement passing from SQL 2000 to 2005 ...
‎07-22-2009 12:16 PM
‎07-22-2009 01:08 PM
Lansweeper wrote:
Do you get an error when you run it? or command completed successfully
‎07-21-2009 01:02 PM
alter view web30OScount AS SELECT TOP 100 PERCENT ISNULL(dbo.tblOperatingsystem.Caption, 'Not scanned') AS OS, COUNT(dbo.tblComputers.Computername) AS Total
FROM dbo.tblComputers LEFT OUTER JOIN
dbo.tblOperatingsystem ON dbo.tblComputers.Computername = dbo.tblOperatingsystem.Computername
GROUP BY ISNULL(dbo.tblOperatingsystem.Caption, 'Not scanned')
ORDER BY COUNT(dbo.tblComputers.Computername) DESC, ISNULL(dbo.tblOperatingsystem.Caption, 'Not scanned')
‎07-21-2009 01:27 PM
Lansweeper wrote:
try from the sql execute console:alter view web30OScount AS SELECT TOP 100 PERCENT ISNULL(dbo.tblOperatingsystem.Caption, 'Not scanned') AS OS, COUNT(dbo.tblComputers.Computername) AS Total
Nothing good ...
‎07-20-2009 09:19 PM
‎07-21-2009 12:10 PM
Lansweeper wrote:
change to thisSELECT TOP 100 PERCENT ISNULL(dbo.tblOperatingsystem.Caption, 'Not scanned') AS OS, COUNT(dbo.tblComputers.Computername) AS Total
I tryed to make this change but when I do anything else (like execute or save) the old code come back instead of the new one.
I tryed with a new view, put inside the new code but it was the same thing.
I tryed to give all permission and enter as local administrator but nothing change ...
Any idea?
‎07-18-2009 02:58 PM
‎07-20-2009 06:01 PM
Lansweeper wrote:
You will need to change the stored procedure "web30OScount"
I found dbo.web30OScount but I'm not the "King of SQL" ... anyone can help me, please?
‎07-14-2009 05:39 PM
