Options
‎07-10-2015 11:59 AM
It would be very handy if Lansweeper had a "re-scan after deployment" when deploying a package.
This would mean that with one "deploy package" command, you could wake a bunch of PCs up (using the existing wake-on-lan option), deploy, re-scan them and then shut the PCs down automatically (using the existing shutdown option).
A small option, that would make after-hours deployments that little bit simpler! 🙂
Solved! Go to Solution.
Labels:
General Discussion
Options
‎07-17-2015 01:16 PM
There's already an option for this. Every package has a Rescan Assets checkbox. If ticked, the machines will be rescanned when the deployment has completed.
Options
‎07-18-2015 12:38 PM
Thanks Susan, I'm not sure how I missed it but just spotted the option the other day!
Options
