Ithd
Hi
i have two problem:
1 how can i manage multiple domain in the same server for the remote control? (my question is about the permission)
2 why from my pc doesn't work the action like remote or test connection? from the server works fine but i don't understand my brower use the lsremote on the server
thanks
Ithd
i can't trust the domain
CyberCitizen
Honored Sweeper
It all comes down to access permissions. I am in the same boat. Your account that you run Lansweeper with on your PC needs admin permissions on that other domain, otherwise, your account won't have the necessary access.
Our Domain account we run Lansweeper with now has the necessary admin permissions and trust on the other domain so we can run the necessary commands.
Ithd
I resolved the second problem but can i manage the other domain or workgroup pc?
pryan67
Worst case, you can run the rdp client manually from the start menu, and it will prompt you for credentials.
Or, you can do this. Personally I'd use the RDP client manually.
https://www.lansweeper.com/knowledgebase/running-actions-as-a-different-user/
