seth921
I recently updated to Lansweeper 5.1 from 5.0, but have been experiencing this issue in 5.0 as well.
When I open my report builder (Reports -> Create New Report) and enter any SQL query in the field, I can never get the Builder to update)
I've attached a screenshot of the builder screen after I have set up my query and clicked in the above area of the builder to update the page. The query entered is:
tblAssets.AssetID,
tblAssets.AssetUnique,
tblAssets.Domain,
tblFileVersions.Found,
tblFileVersions.FilePathfull,
tblFileVersions.FileVersion,
tblFileVersions.CompanyName,
tblFileVersions.Filesize,
tblFileVersions.CreationDate,
tblFileVersions.LastAccessed,
tblFileVersions.LastModified,
tblFileVersions.Lastchanged
From tblAssets
Inner Join tblFileVersions On tblAssets.AssetID = tblFileVersions.AssetID
Where tblFileVersions.FilePathfull Like '%iexplore.exe' And
tblAssetCustom.State = 1
Order By tblAssets.AssetUnique,
Is there anything that I am missing as far as building this report goes? Or could there be something wrong with my configuration? Thanks,
If you are using IIS, make sure that the application pool is set correctly: http://www.lansweeper.com/kb/48/Lansweeper-5.0-does-not-work-on-manually-installed-IIS-sites..html
seth921
The application pool was, indeed, the issue. I changed to the proper app pool and everything works properly now. Thank you 🙂
