myssv
Hi there,
I see this:
So, was the last scan ok (Last successful scan=now) or not (Red sign at lasst scan attempt)
Jacob_H
Hey MySSV -
That usually means that SNMP once or used to work, but the latest scan it didn't.  Example:  I have a network device at home where the SNMP service on it kept crashing.  Once I restarted the service, it would scan and the error would go away, until I fixed it in general.  There's a tool included that can test SNMP, details here:  Troubleshoot SNMP scanning issues - Lansweeper Community
myssv
I found the solution at the switch. There was an option to de/activate SNMP .....
Jacob_H
Hey MySSV -
myssv
Hi Jacob,
thanks for your respond. I tested it with the Device Tester an got this result:
Lansweeper DeviceTester 7.1.0.1
	Status: Running
	Version: 12.5.4.0
Pinging 192.168.115.99
	Ping ok.
	TTL: 254
Scanning TCP ports..
	Open ports:
		21 (FTP)
		22 (SSH)
		23 (Telnet)
		80 (HTTP)
		443 (HTTPS)
	Closed ports:
		25 (SMTP)
		8080 (HTTP)
		135 (EPMAP)
		139 (NetBIOS Session Service)
		8443 (HTTPS)
		445 (SMB)
		9100 (Jetdirect)
		16992 (Vpro HTTP)
		16993 (Vpro HTTPS)
Scanning MAC..
	70:49:A2:21:53:E1
Scanning DNS..
	XMG1915.fritz.box
Scanning netbios (UDP)..
	Could not scan netbios
Scanning FTP..
	220 XMG1915 FTP version 1.0 ready at Tue Aug 19 17:31:28 2025
Scanning SIP..
	Error: Socket exception TimedOut: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat
Scanning HTTP..
	Url: Http://192.168.115.99
	Response Uri: http://192.168.115.99/login.html
	Transfer-Encoding: chunked
	X-Frame-Options: SAMEORIGIN
	X-Content-Type-Options: nosniff
	Cache-Control: no-cache
	Content-Type: text/html
	Date: Tue, 19 Aug 2025 17:31:31 GMT
	Expires: Thu, 26 Oct 1995 00:00:00 GMT
	Set-Cookie: C1=youshallnotpass; path=/; HttpOnly; SameSite=Strict
	Server: Allegro-Software-RomPager
	Title: Login
Scanning HTTPS..
	Url: Https://192.168.115.99
	Certificate issuer:
		CN=XMG1915 7049a22153e1
	Response Uri: https://192.168.115.99/login.html
	Date: Tue, 19 Aug 2025 17:31:34 GMT
	Title: Login
Scanning SSH..
	SSH server: SSH-2.0-OpenSSH_3.9p1
	Error: No password
Scanning SNMP..
Scanning VPRO RMCPPing..
	No reply to RMCP ping
Scanning DNS-SD..
	No reply to DNS-SD
Scanning UPNP..
	No reply to UPNP
Done.
I don't know what could be the problem, as it worked before.
SNMP Setting of the switch
What can I do?
ICPMuenchen
we have the same problem with a HP Printer. Devicetester says SNMP disabled or wrong, but paessler snmp tester e.g. can read successfully. We opened a ticket at support for further investigation.
