‎11-21-2024 04:12 PM
So, one thing that me and my coworkers often run into and is very annoying is the Links above the tab being way to sensitive. We can have our open tabs in Lansweeper, and if we move just a little bit either the dashboard dropdown menu will cover our tabs or the assets or reports or any of them will. It gets really annoying that we have to then move away, wait the few secs only to go back to our tabs and hope our mouse does not trigger the drop down menus. It there anyway that in future versions a click only option could be added to the settings so that way the dropdown menu will not happen unless we click on the dashboard or any of those? Just an annoyance that several of us would love to get rid of.
‎12-04-2024 10:05 PM
I find it annoying too. But I think I've managed to get uBlock Origin's "Block element" tool to disable them. It's a little tricky, but if you select the entire part that drops down on one of the links, it disables it on all of them.
‎11-21-2024 05:24 PM
Hi there,
The feature you're looking for is currently unavailable in Lansweeper. However, we would be happy to assist you in submitting a feature request to our product team. To do so, we kindly ask that you contact our tech support team: https://www.lansweeper.com/contact-support/
