04-24-2023 04:31 PM - last edited on 04-02-2024 11:21 AM by Mercedes_O
I would like to be able to track inventory of our on-hand printer toner. I have created an asset and created the QR code. BUT, I don't see where I can put in a qty, or have found no documentation on how to add/remove. Has anyone been able to set this up? We don't have a dedicated scanner, will probably just use iphones, but not opposed to other equipment. I just want to know if LS would be able to do this.
Solved! Go to Solution.
04-27-2023 06:49 PM
You could use a Custom Filed in the asset to track the Qty. Then run reports against those assets and include the custom fields. You'd have to update the Qty fields manually though.
I track our plant equipment in a similar fashion, but for maintenance purposes, tickets against the equipment and calendar scheduling.
04-27-2023 06:49 PM
