ABast
I am having troubles with Lansweeper scanning SNMP of our switches. We disabled v1/v2 in favor of v3. We configured v3 on the switches and tested using the Device Tester tool with success. I made sure that it responded to  OID 1.3.6.1.2.1.1.2.0 as a step in the KB article about scan issues. Everything is working except whenever I scan the device from the Lansweeper console. I have also tried adding a custom OID scan in scanning targets, as well as putting the SNMPv3 credential above global credentials in the scanning target.
ABast
I figured it out......... The username for SNMPv3 is case sensitive by the way..... 😔
ABast
Obi_1_Cinobi
Hello there!
Thank you for sharing the solution, and good catch! ðŸ˜Š
