Grausam
Is it possible to configure LAN Sweeper that way, that I connect with ThightVNC instead RDP to our Clients?
Thank you in advance for yor help
br
Thomas
Grausam
Thank you for your answers.
I changed in the Asset Configuration the Remote Desktop Action to:
cmd.exe /K "C:\Program Files\TightVNC\tvnviewer.exe" -host={smartname}
Now it works fine for us
SO long
Thomas
6 REPLIES 6
sha43
i used exactly this coomand but did not work for me.
I got a error message : '' the command is missspelled or could not be found''
Grausam
SO long
Thomas
sha43
i used this command:
cmd.exe /C "C:\Program Files\uvnc bvba\UltraVNC\vncviewer.exe" -host 10.13.7.100
with this command i connect connect with this certain Pc, but if I want to  connect other PCs too then how can I write the command ?
SO long
Thomas
I know this post is quite old, but this did help me get VNC up in my Lansweeper but...the /K flag keeps the cmd window open even after the vnc window is closed. If you use the /C flag instead the cmd window will close when the VNC window is closed.
Mister_Nobody
Honored Sweeper II
I use VNC in such manner: {actionpath}tvnviewer.exe -host={ipaddress}
You must to have installed VNC Server on your clients.
PeterJG
check deployment section how to push tightvc to user.. and just configure action or do manual connection from your PC based on PC Name
