soucyinter
I've been trying to figure out (I've also searched the forum) how to use the advanced actions on a PC from my computer instead of the server itself but have failed...
First of all, Remote Control is not registered if I use the web interface from my computer (my user account). If i'm on the server account, it works.
The thing is I don't have access to the admin account, but I need to be able (as a network tech) to use these actions from my PC.
How to do so?
Also, when I connect to the server using my special account (not administrator account), I can't connect to Lansweeper Configuration when it asks for the credentials.
Where do we add other accounts to have access to the DB ?
Thank you very much.
see this link: http://www.lansweeper.com/kb/how-to-register-the-premium-tools.aspx
How to do so?
You need to have administrative permissions on the target computer.
Use sql authentication and user "lansweeperuser"
tomecheq
You may use GPO and restricted groups. Create new user account in ActiveDirectory, set strong password. Then talk with your Domain Admin to set GPO with restricted groups in which define that new created account is the member of local administrators group on desktops.
Run browser with that user credentials and computers should be scanned and you will have access to this computers by the lansweeper web page.
soucyinter
tomecheq wrote:
Thanks tomecheck, I didn't do all what you said but I have a user account which I use only for security purposes and when I install new PC, joining to domain, such kind of stuff. I opened IE using these credentials and I have access to the main function we need. Some others don't work (connection refused, like VNC Viewer) but I don't care too much for now about these.
Best regards,
Mario.
The scanning account must have administrative permissions on the client and must have read only access to active directory.
We recommend a domain admin because this is the easiest way for most customers, but you can choose any account you want.
How to do so?
soucyinter
Thank you for the answers, it worked.
How to do so?
Now the problem left is, even though Advanced Actions are registered, I have no access to WMI.
You say I need administrative permissions on the target computer. This means we'd have to be domain admins?
There must be a different way because we'll never get these access from our IT Administrator.
How do people usually configure this?
Thank you again.
