Philippe_Cameli
I have just installe Lansweeper, and I dscover that a VM "burn" 2 asset licne:
- one as ESX Guset
- one as Windows server (or Linux or windows 7/10)
Is there any way to "tell" Lansweeper it is the same Asset ?
I haven't yet found any info in the forum to solve this problem
Update.
I finally read a post about merging asset with the same MAC adress
Any help about doing this ?
Best Regards
PhilippeC.
Philippe_Cameli
OK
Thanks for the reply
NicholeKaligian
If you're still seeing this issue in the latest 7.2.105.2 build after deleting the duplicates manually, I'd recommend reaching out to support so they can look into this further.
