What is a best practice to keep your scanning queue running smoothly at all times?
What is the best practice to keep your scanning queue running smoothly at all times?
View Entire Topic
removed
Solution
To keep your Lansweeper scanning queue running smoothly, here are some best practices:
  1. Optimize Scan Frequency: Adjust the frequency of scans for different targets. Critical assets might need more frequent scans, while less critical ones can be scanned less often.
  2. Distribute Load: Use multiple scanning servers to distribute the load evenly. This helps prevent any single server from becoming a bottleneck.
  3. Adjust Ping Timeout: For IP Range scanning targets, setting the ping timeout to 1 second instead of 2 can significantly reduce scan times, provided your network can handle it.
  4. Manage Scanning Threads: Increase the number of scanning threads in the Lansweeper configuration to allow more simultaneous scans.
  5. Monitor and Troubleshoot: Regularly check the scanning queue for any stuck assets and adjust performance scanning settings if necessary.
  6. Use Asset Radar: Enable Asset Radar to continuously monitor network traffic and automatically identify new or rogue devices.
Implementing these practices can help ensure your Lansweeper scanning queue remains efficient and effective.
Additionally, our support team has created a Quick Tech Solution on how to tune Lansweeper for optimal performance: https://community.lansweeper.com/t5/quick-tech-solutions/tuning-lansweeper-for-optimal-performance/b...
You might also want to review which Lansweeper setup is right for you: https://community.lansweeper.com/t5/installation/which-lansweeper-setup-is-right-for-you/ta-p/64593
