leblanc_daniel_
I wish if it possible to be able to see what monitor was connected to a machine and remove.
The reason is i have seen monitor that where added to a PC that was not suppose to added.
So if i have a user that had a 19inch HP and a month later has 2x 24 samsung, he says alway had 2 monitors of 24 inch and we have no documentation about this, if there was a history of the change from 19 inch to 24, added new monitor when?
Thank you
Daniel
The report we provided only lists monitor *changes*, not all monitors in your network. To list all monitors, you need to build a report based on tblMonitor, not tblMonitorHist (which only stores monitor changes).
leblanc_daniel_
Thank you, i have tried it and it only pop over 166 PC on around 1000 pc (166/1000), missing a few..loll
help
Dan
Please use the report below to list monitor changes. Note that monitor changes will only be tracked if the History checkbox of the Monitor item is ticked under Configuration/Scanning Setup/Item Wait Time.
tblAssets.Domain,
tblAssets.Username,
tblAssets.Userdomain,
tblAssets.IPAddress,
tblAssets.Firstseen,
tblAssets.Lastseen,
tsysOS.Image As icon,
Case tblMonitorHist.Action When 1 Then '+' When 2 Then '-' End As Change,
tblMonitorHist.MonitorModel,
tblMonitorHist.SerialNumber,
tblMonitorHist.MonitorManufacturer,
tblMonitorHist.ManufacturedDate,
tblMonitorHist.LastChanged
From tblAssets
Inner Join tblMonitorHist On tblAssets.AssetID = tblMonitorHist.AssetID
Order By tblAssets.Domain,
tblMonitorHist.LastChanged Desc
Product Discussions
