‎02-13-2024 11:43 AM
Hi Team,
I'm using trail period of Lansweeper and added few nodes. Also, added ESXi host to check his discovery but post adding not able to find full details of host like VM that are hosted on it and other product details.
I have referred this video to add esxi host in Lansweeper: how to add esxi node to lansweeper - Google Search
Could you please help us in auto discovering the VM which are hosted in ESXI? or to get full details about the host?
Thanks,
Shoaib
‎02-15-2024 01:43 PM
Can you open esxi Web-console via browser from ls server?
‎02-14-2024 11:56 AM - edited ‎02-14-2024 04:27 PM
‎02-14-2024 12:21 PM
Both the article has been verified and followed same but no luck. Is there any other way to TS this issue?
Any services that need to be validate in host or ports that need to open to discover the guest VMS?
Note: I even tried with host local account with Administrator role (which has more privilege than read only).
I run the Test connector for that host. PFA the attached file for more info.
‎02-15-2024 10:15 AM - edited ‎02-15-2024 10:17 AM
I re-tested ESXi.
1. Device tester supports ESXi. "c:\Program Files (x86)\Lansweeper\Actions\Devicetester.exe"
2. My result:
‎02-15-2024 01:34 PM
‎02-14-2024 03:50 PM
You have to use scantesttool from ls server
‎02-14-2024 04:58 PM
Can you please share the steps to test/use Scantesttool
‎02-14-2024 05:41 PM - edited ‎02-15-2024 04:15 AM
Run tool "c:\Program Files (x86)\Lansweeper\Service\Lansweeper.TestTools.App.exe"
Select vcenter/esxi
Set IP and creds
View log
‎02-15-2024 09:51 AM
