moss
Hi Lansweeper Admin,
I have tried searching all over web but could not find a solution. Do you have any recommendation as to how would I be able to integrate IPAD scanning with lansweeper. I would like to audit all my assets with a barcode scanner and an IPAD and would like to carry an IPAD and make an inventory and the later sync it to the lansweeper database and vice versa. Do you know any app that can do this or does the new version of lansweeper have this capability to sync with an IPAD.
Any help would be appreciated.
12 REPLIES 12
sandve wrote:
Lansweeper wrote:
You can create a new device type and add the devices manually.
We may have to consider that; but iPads (and other non Microsoft OSes) are computers and do not fit the device mold.
We are aware of this problem.
Version 5.0 will migrate everything (computers & devices) to "Assets"
sandve
We too would like to use Lansweeper to inventory iPads, even if it's a manual process. They won't be on the network, but need to be tracked. Perhaps we'll be able to create a 'LsPush' type file to be imported?
pjbate
Hi there, yes I too am keen to see how we can manage iPads in the organisation. We just had our CIO drop two on the helpdesk and asked to 'work them out' Drop everything!! 🙂
