sullivane
When creating multiple QR Codes, it seems that it has the device name and QR code, which is perfect. However next to the asset name is (#) with # being the number of device that you picked. So if you picked 10 devices it will be which ever number it is (1-10).
Is there a way to get it to NOT do that? It's a meaningless number that could cause confusion if used (if people left and new people hired).
sullivane
Looks like you are right. It's the asset number. An option to not display this would be awesome.
sullivane
Well hiding it would be a nice feature. If we ask people for their computer name they will not know that that number is not needed.
Karel_DS
The number shown should be the asset's ID, which in case you've chosen to generate the QR code using the asset's ID should be same as the end of the URL (if shown). This number can currently not be hidden.
We're still taking note of all user input for this feature, and might add extra options in the future.
