ghelpdesk
Perhaps I've missed something but it seems the export to XLS is limited to Excel2003 format and size limitations.
Would it be possible to cater for Excel2010?
I assume the old standard is used for compatibility reasons. I've added your request to our wish list, though I'm unsure if/when this will be implemented. I would recommend splitting your report into smaller reports for now or exporting to a different file format (.csv, .xml) that supports more lines.
