Last year we already wrote about dropping support for several SQL Server and OS versions. The final chapter is ending soon.
On March 1st, 2023, Lansweeper will end support for these SQL Server and OS versions.
To make sure that you will still be able to upgrade your Lansweeper installation without issue, please review if your installation meets these requirements:
  • Database: SQL Server 2014, SQL Server Express 2014 or higher
  • Database: built-in SQL Server LocalDB
  • Desktop OS: Windows 10 version 21H2 or higher
  • Server OS: Server 2012 or higher
You can refer to our installation requirements blog post for a detailed list of requirements.
Are your SQL server and operating system hosting Lansweeper still up to date? Great, then you're all set!
If not, now what?
No worries, you can easily migrate Lansweeper to a new server by following the instructions in our migration knowledge base article.
Please note that the scanning requirements will remain unchanged. You can find more information on these changes in our installation requirements blog post.
Did you have a similar issue and a different solution? Share your work in the comments below and help your fellow IT Heroes!
2 Comments
