ashley_420
I am very bad at writing SQL queries, I need help to generate a report with following information:-
Asset Name
Asset Type
OS
Manufacturer
Model
Total Memory(in GB
Processor
Disk with capacity in GB
State
Serial Number
Last user
First Seen
NIC
IP ADDRESS
Monitor
Any help is highly appreciated.
Also, I would appreciate any documentation to write effective queries to generate reports.
RCorbeil
Honored Sweeper II
Start with your basics. The core of what you're looking for is in tblAssets.
SELECT TOP 1000000
tblAssets.AssetID,
tblAssets.AssetUnique,
Ceiling(tblAssets.Memory / 1024) As [Memory (GB)],
tblAssets.Processor,
tblAssets.Username,
tblAssets.Firstseen,
tblAssets.IPAddress
FROM
tblAssets
Add the make/model/serial details by linking to tblAssetCustom.
SELECT TOP 1000000
tblAssets.AssetID,
tblAssetCustom.Manufacturer,
tblAssetCustom.Model,
tblAssetCustom.SerialNumber,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
INNER JOIN tblAssetCustom ON tblAssetCustom.AssetID = tblAssets.AssetID
Pick up the description of the state by linking that against tblState.
SELECT TOP 1000000
tblAssets.AssetID,
tblState.StateName,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
INNER JOIN tblState ON tblState.State = tblAssetCustom.State
Assuming you're only interested in the active devices, add a condition to filter for only those.
WHERE
tblAssetCustom.State = 1
Pick up the description of the asset type by linking tblAssets against tSysAssetTypes.
SELECT TOP 1000000
tblAssets.AssetID,
tSysAssetTypes.AssetTypeName,
tblState.StateName,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
INNER JOIN tSysAssetTypes ON tSysAssetTypes.AssetType = tblAssets.AssetType
WHERE
Link tblAssets against tSysOS for basic operating system information.
SELECT TOP 1000000
tblAssets.AssetID,
tSysOS.OSName,
tSysOS.Image AS Icon,
tblState.StateName,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
INNER JOIN tSysOS ON tSysOS.OSCode = tblAssets.OSCode
WHERE
For the hard drive, monitor and NIC, things get a little more interesting because any given computer can potentially have more than one of each.
First, the hard drive. Assuming you're only interested in the primary, we'll filter for that. The drive details are found in tblFloppy.
SELECT TOP 1000000
tblAssets.AssetID,
tSysOS.OSName,
Ceiling(tblFloppy.Size / 1000 / 1000 / 1000) AS [Hard drive (GB)],
tblState.StateName,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
INNER JOIN tblFloppy ON tblFloppy.AssetID = tblAssets.AssetID
WHERE
AND tblFloppy.Name = '\\.\PHYSICALDRIVE0'
That covers the basics of what you're looking for. Adding the monitor and NIC can result in multiple result records per computer (e.g. if a computer has two monitors and two NICs, that's four rows). Personally, because of this, I have separate reports so that I don't get multiple output of the basics. But we're looking at what you asked for, so let's go for the multiples.
Monitor info is recorded in tblMonitor.
SELECT TOP 1000000
tblAssets.AssetID,
tSysOS.OSName,
tblState.StateName,
tblAssets.Username,
tblAssets.IPAddress,
tblMonitor.MonitorManufacturer,
tblMonitor.MonitorModel,
tblMonitor.SerialNumber AS MonitorSerial
FROM
tblAssets
INNER JOIN tblMonitor ON tblMonitor.AssetID = tblAssets.AssetID
WHERE
And finally, the NIC. Details are recorded in tblNetwork.
SELECT TOP 1000000
tblAssets.AssetID,
tSysOS.OSName,
tblState.StateName,
tblAssets.Username,
tblNetwork.Description AS NIC,
tblNetwork.IPAddress AS [NIC IP],
tblNetwork.IPSubnet,
tblNetwork.MACAddress,
FROM
tblAssets
INNER JOIN tblNetwork ON tblNetwork.AssetID = tblAssets.AssetID
WHERE
AND tblNetwork.IPEnabled = 1
ashley_420
Excellent!! Could not have asked more. Thanks a lot RC62N
RCorbeil
Honored Sweeper II
SELECT TOP 1000000
tblAssets.AssetID,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
SELECT TOP 1000000
tblAssets.AssetID,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
SELECT TOP 1000000
tblAssets.AssetID,
tblState.StateName,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
WHERE
SELECT TOP 1000000
tblAssets.AssetID,
tblState.StateName,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
WHERE
SELECT TOP 1000000
tblAssets.AssetID,
tSysOS.OSName,
tblState.StateName,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
WHERE
SELECT TOP 1000000
tblAssets.AssetID,
tSysOS.OSName,
tblState.StateName,
tblAssets.Username,
tblAssets.IPAddress
FROM
tblAssets
WHERE
SELECT TOP 1000000
tblAssets.AssetID,
tSysOS.OSName,
tblState.StateName,
tblAssets.Username,
FROM
tblAssets
WHERE
SELECT TOP 1000000
tblAssets.AssetID,
tSysOS.OSName,
tblState.StateName,
tblAssets.Username,
FROM
tblAssets
WHERE
