NCI_Matt
Hello all,
So I have used the code provided here for a long time when making reports on specific software. In this case though I need the report to only show workstations, and not any servers. Is that possible?
KevinA-REJIS
Try this out:
  tblAssets.AssetUnique,
  tblAssets.Domain,
  tblAssets.Username,
  tblADusers.Displayname As [User],
  tblSoftwareUni.softwareName As software,
  tblSoftware.softwareVersion As version,
  tblSoftwareUni.SoftwarePublisher As publisher,
  tsysOS.Image As icon
From tblSoftware
  Inner Join tblAssets On tblSoftware.AssetID = tblAssets.AssetID
  Inner Join tblSoftwareUni On tblSoftware.softID = tblSoftwareUni.SoftID
  Left Join tblADusers On tblADusers.Username = tblAssets.Username And
    tblADusers.Userdomain = tblAssets.Userdomain
  Inner Join tblDomainroles On tblDomainroles.Domainrole =
      tblComputersystem.Domainrole
Where tblSoftwareUni.softwareName Like '%ExampleSoftware%' And
  tblAssetCustom.State = 1 And tblDomainroles.Domainrolename In
  ('Stand-alone workstation', 'Member workstation')
Order By tblAssets.AssetName,
  software,
  version
8 REPLIES 8
NCI_Matt
This works perfectly Kevin! Thanks!  I hate to ask but i'm also fighting with what is essentially a reverse of this report as well. It's a software missing audit as show here.  Is it also possible to make something like this for workstation only?
KevinA-REJIS
Sure thing, I've got a couple similar reports for missing software, see if this one will work:
  tblAssets.Domain,
  tblAssets.Username,
From tblSoftware
Where tblAssets.AssetID Not In (Select Top 1000000 tblSoftware.AssetID
    From tblSoftware Inner Join tblSoftwareUni On tblSoftwareUni.SoftID =
          tblSoftware.softID
    Where tblSoftwareUni.softwareName Like '%ExampleSoftware%') And
Didnt quite work, unfortunately. This gave me a repeating list of every workstation repeating for every software they had that was not like %ExampleSoftware%
 So for example it listed one workstation 20 times because it had 20 software items that didnt match %ExampleSoftware%
I actually had a similar result about an hour ago while fighting with this.
KevinA-REJIS
I knew I should have tested that first, forgot an important word at the beginning:
Select Distinct Top 1000000 tblAssets.AssetID,
  tblAssets.Domain,
  tblAssets.Username,
From tblSoftware
          tblSoftware.softID
Order By tblAssets.AssetUnique
Still not working out after that last one unfortunately. I'm currently working off the code from here, but trying to add in the tblDomainroles.Domainrolename In ('Stand-alone workstation', 'Member workstation') from your original reply, but so far I havent had any luck.
KevinA-REJIS
Man, yesterday was not my day, I copied the wrong code the second time >_<.
I edited that reply, the report should (hopefully) work now.
That got it! Thanks very much!
KevinA-REJIS
Try this out:
  tblAssets.Domain,
  tblAssets.Username,
From tblSoftware
  software,
  version
Reports & Analytics
