Jrobinson
Upgraded to 3.5 yesterday. The sql script seemed to lock up and I ran it manually in the SQL management studio. After that the Ls web console including tools seemed to work. I noticed later in the day that no machines were updating even after a trigger scan and the queue was not running.
In the application event log I noticed error event ID's Event Type: Failure Audit
Event Source: MSSQL$SQLEXPRESS
Event Category: (4)
Event ID: 18456
Date: 3/12/2009
Time: 9:12:35 AM
User: NT AUTHORITY\NETWORK SERVICE
Computer: HM-2K3-INVENTOR
Description:
Login failed for user 'NT AUTHORITY\NETWORK SERVICE'. [CLIENT: <local machine>]
And
Event Type: Error
Event Source: Report Server Windows Service (SQLEXPRESS)
Event Category: Management
Event ID: 107
Date: 3/12/2009
Time: 9:12:35 AM
User: N/A
Description:
Report Server Windows Service (SQLEXPRESS) cannot connect to the report server database.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
I made no changes to the logins prior to the upgrade, so there shouldn't be any permission issues.
Getting this error when loading the website:
System.Data.SqlClient.SqlException: A connection was successfully established with the server, but then an error occurred during the login process. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.)
Could you post the errorlog.txt from your service please.
Unfortunately I didn't save it. I have lansweeper running on a VM and decided to revert the machine to a snapshot and retry the install. It worked the second time.
