Scott_Talley
nothing at all happens when I click on an Advanced Tool (remote control, etc.) after 4.1 upgrade. I can launch them fine from the c:\program files\lansweeper\actions directory.
Scott_Talley
sorry.. it is the Advanced Actions and the problem seems to be there is no "Lansweeper$" share set to the c:\program files\lansweeper\actions directory. Made that change and it's working now.
Scott
gmitrana
Is it about "Advanced tools" or "advanced actions"?
Which browser are you using?
Do you see any javascript errors in the console.
Are the other tools working ok.
